Results 1 to 10 of 16
Thread: Alarm going off randomly...any ideas?
    Port Jeff Ny
    Default Alarm going off randomly...any ideas?
    After turning off and locking vehicle, the vehicle alarm will sound off randomly as the title states. Any ideas as to why this is happening? everything else works perfectly.
    Show
    V6 Tails / Camaro SS Wheels w/ Nitto NT555 Tires / Camaro SS Brake Kit / GXP Diffuser & GXP Bumper Conversion
    Handling
    Pedders GSR Struts w/ Pedders Sport Springs
    BMR Fabrication Full Bushing Kit / BMR Front and Rear Sway Bars / BMR Tunnel Brace / BMR Subframe Connectors / BMR Strut Bearing
    Spohn Lower Control Arms w Del Sphere Pivots / Spohn Toe Rods w Del Sphere Pivots / Spohn Trailing Arms w Del Sphere Pivots / Spohn Sway Bar End links
    Sound
    Cowon S9 32gB/ Zapco Ck 16.2 Competition Components / Audison Lrx5.1K / Arc Audio 8" woofers x 2 / JBL MS8 / Wiring by KnuConceptz
    Custom Fiberglass Sub Box by NDM FOR SALE
    AudioControl DQL8 FOR SALE
    pissing'n wind = wet face stryker g8gt's Avatar
    G'ville, SC
    possible low battery in remote??
    V8 Muscle
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
    Junior Member MagneticSmoke's Avatar
    Sep 2011
    I'm currently having this same issue.
    Did you ever find a fix to the issue?
    Wonder Lake, IL
    I'm having the same issue. Any ideas?
    Wonder Lake, IL
    So the alarm will randomly go off for about 15-20 seconds, then it turns itself off. The remote start is also no longer working. I've checked to make sure all 4 doors, hood and trunk are completely shut. I've tried the remote start with both remotes. Lock/unlock work fine. The parking lights blip like it should just before starting, but it just never attempts to start. Anyone have any ideas as to what could be wrong?
    Hood shut sensor?
  7. Likes STL_G8GT liked this post
  8. #7
    Hood shut sensor?
    That would be my guess. Check engine light on?
  9. #8
    Wonder Lake, IL
    Check engine light is not on. The alarm started going off randomly a couple months ago. The remote start only stopped working a week or so ago. I'm outside of my warranty and am hoping to avoid any expensive diagnostic trips to a dealer / repair place if this may be something simple. Any help on what to look for would be much appreciated.
  10. #9
    same here - very very common with age.
    either the sensor is broken - minor cost, or the hood stops need adjusting to reset the switch depth.
    However - IIRC - if the hood switch shows open, when the alarm goes off - isn't there a DIC message Alarm activated Hood?
    I know my GTO did that.
  11. #10
    Wonder Lake, IL
    I'm not sure if there is a DIC message or not, as when the alarm is activated, it turns itself off within about 20 seconds or so. I usually don't get to my key fob in time to turn it off, let alone get inside the car to see anything. I've just stopped locking my car for the time being (no real concerns with where I work / live), but it would be nice to have the remote start work again before winter hits.
