Results 1 to 9 of 9
Thread: Random Technology Highflow Cats
    clark, mo
    Default Random Technology Highflow Cats
    Looks like my cats may be gone on my maggie g8. We've been running a little too rich setup I think and the cats may be the problems I was having on the dyno. I read some stuff on the Random Technology Cats and they appear to be the best on the market by a shit load. Has anyone else bought a set of these. I want to get a set of new cats and then do a retune and fix this issue when I get back from vacation next week.
    Junior Member MYSRMGXP's Avatar
    Lake Jackson
    I had no problem with thier cats i put on my truck!!!!
    Central Florida
    If you don't have inspections you should go without.
    clark, mo
    We do have Missouri inspections every 2 years.
    Central Florida
    Bummer.
    Sent from my DROID2 using Tapatalk
    Smyrna, TN
    If they just have an obdii test and a visual inspection, you could have someone gut the cats and weld in an internal test pipe that they couldn't see. The obdii is easy to get around. Visually it would look like it had cats...
    I've heard you shouldn't just gut the cats though because it causes back pressure issue going from higher to lower to higher restriction. i.e. header to cat to cat back exhaust pipe.
    Livernois Stage 1 cam, valve job, milled heads, ported intake, kooks mid length 1 7/8 headers, corsa cat back, rotofab CAI, Pedders XA Street Kit, BMR trailing arms.
    427 RWHP / 397 RWTQ
    Vertini Riviera 19 x 8.5 and 19 x 9.5. Bridgestone Pole Position 245/40/19 Fr and 275/35/19 Rr
    VIP Member G8 GT V8's Avatar
    Fairfield, Ohio
    Or you could just put the cats on before you go to the inspection facility, pass the inspection, and then put the cat-less pipes back on. Just don't tell them I told you to do it...
    Marty
    G8 gone, but not forgotten...
    Feb 2009
    Oxford,Pa
    Quote Originally Posted by locrzn#92 View Post
    Visual or just OBDI
    clark, mo
    Visual.
