Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: key FOB battery
    GOT TOOLS? Struggle's Avatar
    NW Iowa
    Default key FOB battery
    What kind and where do you get a battery for the key fob.
    Mine will usually only work once and then quit until a little while later it will work again like it might have a weak battery.
    Insert tool at angle and pry back to seperate two halves with enough effort release the tab.
    Note angle of tool once to halves release
    Two halves apart with one flipped over
    Gently sperate battery cover
    Make sure to put battery in the same way and reverse to put back together by sliding everything back and you will here a snap when the to halves slide together.
    Same procedure for fixed key. One 2032 battery is needed.
    2009.5 G8 GT Silver
    NW Iowa
    Disregard.
    Found out it is common 2032 and replaced it.
    Seems to work better as in it can be pesuhed several times and it continues to lock and unlock doors. No improvment in the range though.
    I did not have to reprogram it so it seems so far. I have not driven the car though.
    2009.5 G8 GT Silver
    Jan 2010
    Have any trouble spilling the fob open? I'm gona do mine soon and I'm afraid of breaking some of the tabs.
    NW Iowa
    NO problems there but I have a thin stout tool from Snap On that worked very well. YOu stick it in at an angle and push the cover back. I at first kepts stick the tool in straight and got no where that way.
    Also the remote still does not work any better. If I try to lock the doors from more than say 50 feet away I can get them to lock once and after that it does nothing. The RKE system on this cars sucks big balls. We can start our Tahoe from what seems like a block away and this car you have to be practically sitting in it for the remote to work.
    We have two remotes for it and both are the same. for lack of working properly.
    2009.5 G8 GT Silver
    West Virginia
    Can you expand a bit on the how-to for this? Mine seems to be dying on my switchblade fob.
    9 Second G8
    Addicted Member Snakey's Avatar
    Jan 2009
    Granger, Indiana
    X2!
    2009 Stryker Blue G8 GT
    Mods Completed So Far:
    Custom Painted Engine Cover - Auto Dimming Mirror
    Pypes Axel-Back Exhaust - DDM 55W 6000K HID's
    VLED Backup LED's - Holden V8 Badges - Stubby Antenna
    Homelink Opener in Visor - Vararam OTR Intake - TSS Atari Plaque
    UPR Catch Can - GXP Diffuser - JettStream HSRK & Vararam Coupler
    Contact me via PM if you are interested in a Homelink Visor!
    NW Iowa
    Do you mean to open the case?
    2009.5 G8 GT Silver
    Nov 2008
    Charleston, SC
    My switchblade keyfob died all together. It would work for a day or 2 then I would have to reprogram it to the car. I ended up replacing thebattery but ended up nneeding a new electronics in it. Replaced under warranty, havnt had a problem since.
    2009 Maverick Silver G8 Gt
    VaraRam, Fasterproms Ported LSXR 102 & Ported Throttle Body, Comp Cams Trunions, UPR Catch Can, Holden Radiator Cover, BMR Sway Bars, BMR SFC's, BMR Tunnel Brace, BMR LCA's, CTS-V Wheels, GXP Brake Kit, Pedders Lowered Springs and Dampeners, GXP Rear Diffuser, Hacked Atari Gauges, Sliding Leather Armrest, Spencers 5000K Lows/fogs, GRRRR8 Heater Hose Relocation, EFILive V2, 35% Window Tint
    To install: BMR complete bushing kit, BMR Toe rods
    VIP Member vert's Avatar
    Nov 2008
    Indiana
    Quote Originally Posted by Snakey View Post
    X2!
    X3, I do remember reading a how to somewhere on the net. If I remember right, open the switchblade key and you will see a opening/slot. I think that slot has something to do with it.
    2008 MGM GT. Patrick G spec'd 222/226 .597/.605 115LSA +3 cam, Ported TB, Ported Manifold, 25% PB UDP, 180* Tstat, Vararam w/HSRK, Kooks 1 3/4" LT Headers, X w/cats and muffs, GXP Diffuser, B Splitter, 6000K HID's, 6.0L Badges, Tinted Side,Rear Markers and Tails, 15% Window Tint, Blackedout Chrome, Ghost Stripes, G2 Red Calipers
    NW Iowa
    I will try and take some pictures tomorrow on this and post it here.
    2009.5 G8 GT Silver
