Results 1 to 4 of 4
Thread: Grrrr8 parts list Body Electrical
    Default Grrrr8 parts list Body Electrical
    Body Electrical
    BATTERY,WIRING,LIGHTS & RADIO
    Daytime Running Lamp Sensor
    25713063 With Auto Temp Control
    15837063 Without Auto Temp Control
    Daytime Running Lamps Module
    15819552 BCM
    Headlamp Bulb
    92095788 High Beam # H9 each
    92095787 Low Beam # H11 each
    Negative Battery Cable
    92213567 All Applicable Models
    Positive Battery Cable
    92216221 Lower
    92185945 Upper
    Gauges
    Engine Oil Level Sensor
    12603780 V6
    12603781 V8
    Fuel Gauge Module
    92203241 V6
    V8 N/A
    Fuel Gauge Tank Unit
    92203247 Primary
    92159798 Secondary
    Oil Pressure Sender or Switch
    12570798 V6
    12616646 V8
    Water Temp Sender or Switch
    12566778 V6
    12608814 V8
    Horn & Wipers
    Horn Assembly
    92199555 High Note
    92199556 Low Note
    92199313 Horn Relay (All Applicable Models)
    Window Washer Reservoir & Fluid Level Switch
    92191904 All Applicable Models
    89001112 or 92191900 Windshield Washer Pump
    92164383 Wiper Motor (All Applicable Models)
    Motors Switches and Relays.
    Courtesy Light Switch (Pillar)
    92215257 Latch assembly, Front Left
    92215256 Latch assembly, Front Right
    92215255 Latch assembly, Rear Left
    92215254 Latch assembly, Rear Right
    92204391 Headlamp Switch (All Applicable Models)
    92207956 Heated Seat Control Module (All Applicable Models)
    92212791 Ignition Lock Cylinder (All Applicable Models)
    92184907 Ignition Switch (All Applicable Models)
    15819552 Keyless Entry Module BCM
    25808838 or 25852909 Keyless Entry Receiver
    92201609 Keyless Entry Transmitter each
    Power Mirror Motor
    92194048 Mirror Assembly Left
    92214581 Mirror Assembly Right
    92190192 Power Mirror Switch Assembly
    92207956 Power Seat Memory Module (All Applicable Models)
    Power Seat Switch
    92145921 4-Way
    92146283 6-Way
    Seat Heater Element Assembly
    92207979 Seat Back each
    92207978 Seat Cushion each
    92204673 Seat Position Sensor (All Applicable Models)
    92191392 Shift Lock Solenoid (All Applicable Models)
    92190131 Stop Light Switch (All Applicable Models)
    92204391 Turn Signal Switch (All Applicable Models)
    92199312 Window Defogger Relay (All Applicable Models)
    Window Defogger Switch
    92215229 HVAC with Auto Temp Control
    92215226 HVAC without Auto Temp Control
    Window Motors & Regulators
    Door Window Motor / Regulator
    92191030 Front,Left,Regulator,Assembly
    92191031 Front,Right,Regulator,Assembly
    92195914 Rear,Left,Regulator,Assembly
    92195913 Rear,Right,Regulator,Assembly
    Power Window Control Module
    92182518 Express Module
    D1981F Express Module (AC Delco)
    Side markers
    LH- 92202363
    RH- 92202364
    Gas cap is 92232541
    Part information contributor: HSV-GTS-300 (Paul)
    Aug 2017
    Doncaster east
    Hi mate could you send me the complete wiring instructions diagram for a centre triple pod gauge on a ve v calais if u could it would be a huge help thanks
    Aug 2017
    Doncaster east
    Hsv centre triple pod gauge that is
    Quote Originally Posted by roxsta1 View Post
    Sorry all I have is the manual for the G8, and it wasn't offered with a triple gauge pod. You'll need to find someone with the down under holden service manuals.
