Results 1 to 7 of 7
Thread: Camshaft Overstock Blowout Special @ Texas Speed!
    Vendors
    TEXAS!
    Default Camshaft Overstock Blowout Special @ Texas Speed!
    We're reorganizing our shipping department, and have too much overstock on a handful of our camshafts. That means it's time for a sale!
    We will be offering $50 off any cam package that includes the following camshafts:
    Magic Stick 4 111LSA
    TorquerV3 111LSA
    TorquerV2 113LSA
    228R 112LSA
    224/228 114LSA (XER/XER)
    224R 112LSA
    Cam package one which includes the camshaft, Beehive .600" lift valve springs, and hardened pushrods will be $539.99 when you select any of these camshafts!
    Cam package two which includes the camshaft, PRC .650" lift dual valve springs, and hardened pushrods will be $639.99 when you select any of these camshafts!
    Pricing has been updated on our website to make ordering simple as well! This sale will run through Monday morning, November 29th at 9am Central time!
    Feel free to call us with any questions you might have about this sale or any of our products!
    Largest Stocking Distributor of LS-x Engines / Largest LS-x Comp Cams Distributor in the Country!
    COMP - FAST - PACESETTER - CALLIES - COMETIC GASKETS - MONSTER CLUTCHES - MOSER ENGINEERING - KOOKS
    ARP - GM BOLTS AND GASKETS - MSD - NGK - POWERBOND - WISECO - ASP - AND MORE!
    Administrator Steve's Avatar
    Olympia,WA
    Nice! - have you guys thought about putting the full package together that GT owners may need? (including lifters, valley cover etc)
    -= R.I.P Charlie =-
    http://g8gt.blogspot.com
    Vendors
    TEXAS!
    We do have AFM/DOD Delete kits available at competitive prices for those who need those pieces!
    Beyond Help Darkmanx's Avatar
    ft lauderdale fl
    have any links to the afm dod delete kit
    Vendors
    TEXAS!
    Yes, sorry I had forgotten to make them active on the website!
    http://www.texas-speed.com/shop/cate...ID=12&catid=43
    Both (AFM and VVT Delete) kits are listed on that page with a detailed description of what is included when you click into each page
    Olympia,WA
    How much for just a Cam - and which of those would be nice & mild (think almost stock GT/GXP like?)
    -= R.I.P Charlie =-
    Vendors
    TEXAS!
    The cams are still $374.99. This special is just for the packages, but we might make a cam only special sometime if there's more demand for it!
