Results 1 to 10 of 16
Thread: Wipers
    Sugar Land Texas
    Wipers - Performance/Cleaning Instructions/Maintenance
    Bulletin No.: 06-08-43-003A
    Date: June 08, 2007
    INFORMATION
    Subject:
    Windshield Wiper Performance, Cleaning Instructions and Maintenance
    Models:
    2008 and Prior GM Passenger Cars and Trucks (including Saturn)
    2008 and Prior HUMMER H2, H3
    2008 and Prior Isuzu Medium Duty Trucks
    2005-2008 Saab 9-7X
    Supercede:
    This bulletin is being revised to add the 2008 model year. Please discard Corporate Bulletin Number 06-08-43-003 (Section 08 - Body and Accessories).
    Wiper Concerns
    Most concerns about windshield wiper performance are the result of dirty wiper blades, damaged wiper blades, or worn out blades that are continuing to be used beyond their useful life. Depending on environmental conditions, wiper blades can have dramatic differences in lifespan. Here are some tips and guidelines to maximize wiper performance to avoid damage to the blades, and to avoid unnecessary replacements.
    Many wiper blades are being replaced under warranty with reviews showing there is nothing wrong with the returned blades other than a build-up of dirt. Additionally, advise the customer to review the information in their Owner Manual.
    Inspection and Cleaning
    Scheduled Maintenance
    Inspect your wipers rubber blades every 4-6 months or 12,000 km (7,500 mi) for wear, cracking or contamination.
    Clean the windshield and the rubber wiper blades (using the procedure below) if the blades are not clearing the glass satisfactorily. If this does not correct the problem, then replace the rubber elements.
    Cleaning Procedure
    Avoid getting windshield washer fluid on your hands. Wear rubber gloves or avoid direct contact with washer fluid.
    Do not use gasoline, kerosene, or petroleum based products to clean wiper blades.
    Clean the rubber blades using a lint free cloth or paper towel soaked with windshield washer fluid or a mild detergent. You should see significant amounts of dirt being removed on the cloth.
    Be sure to wash the windshield thoroughly when you clean the blades. Bugs, road grime, sap and a buildup of car wash/wax treatments may additionally cause wiper streaking.
    Tip
    For a larger scale buildup on the windshield, use a non-abrasive cleaner such as Bon-Ami* (www.faultless.com) cleanser with a wet sponge, being sure to use plenty of water to avoid scratching the glass. Flush the surface and body panels completely.
    Tip
    For day-to-day exterior glass cleaning and to maintain a streak free appearance, suggest Vehicle Care Glass Cleaner, P/N 89021822 (in Canada, 992727). This product is an easy to use foaming cleaner that quickly removes dirt and grime from glass surfaces.
    Tip
    Interior glass should be cleaned with plain, clean water to eliminate any film or haze on the window and help prevent fogging, a major customer dissatisfier. Refer to Corporate Bulletin Number 03-00-89-006D for more information. The New Vehicle Pre-Delivery Inspection form also recommends using plain water to clean interior glass.
    *We believe this material to be reliable. There may be additional manufacturers of such material. General Motors does not endorse, indicate any preference for or assume any responsibility for the products or equipment from these firms or any such items which may be available from other sources.
    Avoiding Wiper Damage
    The following are major contributors to wiper damage. Some of these you can control and others are environmental concerns.
    Extremely dusty areas (such as driving on dirt roads) may cause the wipers rubber edge to wear quickly and unevenly.
    Sand and salt used on roads for increasing winter traction and ice control will cause the wiper blades to wear quicker. Areas with significant snowfall require more frequent blade replacements.
    Heat and time may cause the rubber blades to take a "permanent set" resulting in the rubber not flexing and turning over uniformly. This condition may result in streaking and/or unwiped areas.
    Rubber blades are easily cut or torn when using ice scrapers. Likewise pulling blades up off a frozen windshield can tear the rubber. Exercise caution when clearing ice and snow.
    Using your wipers to "wear through" frost and ice, instead of allowing the defrosters to melt the ice, can dull, nick or tear the rubber blades.
    Banging wipers on the glass to remove ice and snow may cause the blade to bend, dislodging the rubber and causing potential scratching of the windshield.
    Ice can form in the pin joints of the wipers, which can cause streaking and unwiped areas. To remove ice from pin joints, compress the blade and rubber edge with your hand to loosen the frozen joints. Consider using Winter Blades that have a rubber cover to avoid this condition.
    Information supplied courtesy of Alldatapro.com
    VIP Member bobyoung's Avatar
    Millbury, MA
    I noticed two rips in my G8 GT drivers side wiper within two weeks of buying the car and the windshield was not dirty, no negligence on my part caused this to happen. It leaves two water lines across the windshield now, think I'll bring it back.
    Beyond Help Mike P's Avatar
    Midland, MI
    Do they make replacement blades that attach like the OEM blades?
    2009 White Hot G8 GT (stock)
    * SOLD * 222/230 .597/.600 114+4 EPS Cam, Patrick G ECM/TCM Tune, Roto-Fab CAI, HSRK, Yank 3200 Torque Converter,
    Transmission Cooler, Kooks 1 3/4" LT Headers, high flow cats, stock mufflers, Billet Prototypes Catch Can, UD Pulley,
    Ported Intake Manifold, Spohn Trailing Arms
    407 RWHP & 365 RWTQ
    Best Time: 12.517 @ 115.02mph w/ 1.97 60' time - (on stock 18" AS Tires)
    Millbury, MA
    Quote Originally Posted by Mike P View Post
    I couldn't find any, at least at Autozone, they said the attachment scheme was new and not available yet.
    For what it's worth, Consumers tested wipers, and the Rain-X wipers were
    the longest-lasting, but all wipers went bad by about 6 months, so they are
    a consumable alright...
    Midland, MI
    Quote Originally Posted by bobyoung View Post
    I can't wait until they come out with replacement blades with the new attachment scheme.
    Maybe Anco, Bosch, or any of the main brands....
    407 RWHP & 365 RWTQ
    VIP Member Blackrider's Avatar
    Victoria B.C.
    My G6 had the same style wipers and they would do the same thing as the G8 wipers which is leave curved lines across the wiping surface, all I do is take a paper towl and wipe the entire length of the blade once ot twice every time I fill the car up and they work perfect.
    2008 MazdaSpeed 3 - A few Mods
    2009 Panther Black G8GT -
    VMS ECU/TCU Tune, Vararam Intake, FasterProms Ported Intake Manifold & Throttle Body, Doug Thorley LT's mated to a Magnaflow catback with Magnaflow Spun Metallic Cats, & Powerbond UD Pulley
    Ok, I'm going to clean my wiper blades when I fill up now. I never had to with my G6 though. Those were the best wipers I ever had.
    Inventor of Road Rage GT-610's Avatar
    Long Island,NY
    you could clean mine every swipe and it wouldnt matter
    that why i use rain x...so i dont need the wipers that much
    GT,prem,sport pkgs
    hood deflector
    GXP diffuser
    trunk mat
    Infinity 2way doors
    MTX re-q (for subs)
    35% tint all around
    red LED's under dash + seats
    Vararam & HSRK
    Kaltech custom 93 tune
    Solo axlebacks
    Midland, MI
    +1 to Rain X, but I'd still like to get some decent replacement wipers.
    I wonder if I could just have the dealershp order me 2 new replacement wipers.?
    407 RWHP & 365 RWTQ
