Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Wheel Alignment. Caster,Camber,Toe. Specs & Adjustment Info.
    VIP Member toedrag's Avatar
    Aug 2012
    DFW
    Paul, for Toe adjustments, do you happen to know how much rotation (1/4 turn, 1/2 turn, etc) of the front Tie Rod and Rear I-Link adjuster results in X mm of toe change per wheel?
    And, on the I-Link adjuster locknuts, is either one left-hand threaded? I've only done my own alignment on one other car, and the inboard locknut/ball joint (the one closer to the chassis) was left-hand threaded, which is why I'm asking.
    Feb 2011
    Latham NY
    Hey CP - Linky no worky. I just got 92218339 and need SI document ID 2322935 for the installation.
    To adjust caster, order a caster adjustment kit (p/n 92218339). The kit includes one replacement control arm retaining bolt, two offset washers, and one replacement prevailing torque locknut.
    One kit will do one side of the vehicle. Follow SI document ID 2322935 for installation.
    http://www.sandyblogs.com/techlink/2...ment-tips.html
    Dec 2010
    IS the FE3 suspension the same in terms of adjustment?
    2009 GT Premium & Sport Packages
    White Hot with Black/Red interior
    Roto-fab CAI, Roto-fab Rad cover, Tint all around, Baer brake kit red, Aeroforce gauges, GXP steering wheel, shifter, front clip & diffuser, Shark Fin
    Future: Sunroof, suspension, and much more.
    Feb 2011
    Latham NY
    Yes
