Page 6 of 6 FirstFirst ... 456
Results 51 to 57 of 57
Thread: Bulb List for LED Swaps
  1. #51
    OCD DIYer Eidolon's Avatar
    Raleigh, NC
    Quote Originally Posted by Tulsa GT View Post
    U see the 2nd pic I posted? The chip? Is there any chance that behind that chip there are screws holding the sunroof switch hardware in place?
    That I don't know. If there are, that means the installers added them. But I don't believe there's anything behind that to hold the module in place except for the sunroof motor itself, and the sunroof motor should be affixed to the frame for the sunroof, not to the control unit on the headliner. At least that's how the OEM setup is.
  2. #52
    Sep 2011
    2009 GXP KCMO, USA
    Can someone be kind enough to backcheck my LED shopping list from superbrightleds.com . Main concern is bulb size for fitment in stock housing and practical brightness. Thanks
  3. #53
    Sep 2011
    2009 GXP KCMO, USA
    bump I would like to order them today if possible !!
  4. #54
    Nov 2011
    Cincinnati,OH
    Pretty sure you need the 9 led festoon for trunk. 4 is too short.
    Here was my shopping list to do the front markers, license, interior, and reverse
    QtyProduct/OptionsPrice/Ea
    21156-xLX3: 1156 LED Bulb - Single Intensity 1 x 3 Watt High Power LED 1156-WLX3: 1156 Cool White$9.95
    6WLED-x-x: 194 LED Bulb - 1 LED Wedge Base WLED-W-120: Cool White 120 Degree$1.39
    4WLED-x-x: 194 LED Bulb - 1 LED Wedge Base WLED-A-120: Amber 120 Degree
    Sent from my SCH-I535 using Tapatalk 2
    Phillip M.
    Engine: Stock Bottom End
    Cam: BTR IV PD
    Drivetrain: 6L80, Sonnax
    High Compression/Boost/E85
  5. #55
    Sep 2011
    2009 GXP KCMO, USA
    Quote Originally Posted by tweaker47 View Post
    Qty Product/Options Price/Ea
    6 WLED-x-x: 194 LED Bulb - 1 LED Wedge Base WLED-W-120: Cool White 120 Degree $1.39
    got the reverse right. thanks
    assuming the six 194 LED Bulb 1LED Wedge Base WLED-W-120: Cool White 120 Degree is for the 4 dome/map lights and the 2 liscense plate lights ?
    also two 194 LED Bulb - 1 LED Wedge Base WLED-A-120: Amber 120 Degree for the front markers...what are the other 2 for ? spares
  6. #56
    Nov 2011
    Cincinnati,OH
    Quote Originally Posted by screaminChick-n View Post
    Yes
    2 for the repeaters in the fenders and 2 for the markers in the side of the front bumper.
    Phillip M.
    Cam: BTR IV PD
  7. #57
    anyone have issues getting a 7443 LED tail light/brake light bulb to fit the housing.
    I've bought 2 devices both labeled 7443, as the incandescent bulb is labeled. both are 360 devices with LEDs on the end cap which I thought for the way the fixture is designed would light well and thoroughly.
    neither will fit in the housing. fits the holder fine - lights great - but when I go to place into the lamp housing - won't clear the opening.
    compared to a incandescent 7443 - they are both slightly larger in diameter. even the SMD version.
