Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
Thread: Bulb List for LED Swaps
  1. #21
    Beyond Help texn884's Avatar
    Helotes, Texas
    Great List.
  2. #22
    Member DZG8GT's Avatar
    Alden, NY
    Need some help here, I tried an LED bulb for the trunk, its an 4410-xHP12DI. It similar to the glove box bulb except it has 12 LEDs for a 360 degree pattern. When I plug it in it just flashes dimly. Would a resister help or is it just a wrong application for this spot? I thought I read on some other post that this was a optional choice for the trunk.
    [B][COLOR="MediumTurquoise"]MODS: SOLD
  3. #23
    OCD DIYer Eidolon's Avatar
    Raleigh, NC
    Quote Originally Posted by DZG8GT View Post
    The resistor mod for turn signals is not to fix something wrong with the LEDs, but rather to emulate the load of a filament bulb to prevent hyperflash. LEDs use so little current relative to a filament bulb that, without the resistor, your car thinks that there's nothing there and hyperflashes to alert you.
    So a resistor won't help you here.
    One of three things is up.
    1) The voltage that the car is providing is not correct. Filament bulbs aren't sensitive to voltage. LEDs are. If you have a multimeter or know someone who does, make sure you're getting 12 volts.
    2) A bad or loose connection either in the bulb holder or in the LED contacts.
    3) Simply a defective LED bulb.
    Try to nail down 1 and 2, and if those aren't it, you're left with #3!
    Sent from my HTC Incredible using Tapatalk
  4. #24
    Alden, NY
    Well now the bulb will not even light so the no brainier answer is its the bulb. Now to see if I can get it replaced for free since it was $12. Might go with a different kind. Just was worried about the degree of illumination with LEDs
  5. #25
    Oct 2009
    Webster, NY
    I recently tinted my tail lights and I already got pulled over. The trooper said I should get brighter bulbs or replace the whole tail lights with stock. Would these LED bulbs be a lot brighter then stock bulbs for my tail lights?
    Thanks
    2008 NA G8 GT
    1/4 mile = 10.93 @ 123
    60' = 1.47
    DA = 500
  6. #26
    liberalism is pro-retard MoonPie's Avatar
    Hey, anyone know what the requirements are in terms of bulb color or can I have all bulbs the same color? I'm thinking nope but would like same color all around if I can.
    ANARCHINDEREPUBLICADEMOCRATARIAN
  7. #27
    Senior Member piecesparts's Avatar
    Jan 2009
    Anyone changed out the 194 bulbs in the dome lights, yet. What size in lumens did you go with? Did you use a light that is designed like a tower or a flat plate design OR-----? After doing my new GMC truck the car has to have new dome light bulbs.
  8. #28
    Member nifong08iom's Avatar
    Mar 2012
    Warsaw, IN
    I would like to know this as well. Best ones used for tails and turns and backup, exact description on V-LEDs, so we know why to order. Best 194 for dome and map lights?
    2008 G8 GT. Ignition Orange Metallic.
    SHOW: 6000K DDM HID's, 6000K LED Fogs, Interior LEDs, Video In Park from Speedisking, IOM Shark Fin, GXP Diffuser, 15% Tint, 15% tint front/rear reflectors.
    GO: Solo Mach Unbalanced Catback
    Mods coming soon: Roto-Fab Carbon Fiber CAI, EFI Live Tune by Wait4MePerformance, Kooks Mids w/ HFC
  9. #29
    Addicted Member incon3037r's Avatar
    Las Vegas, NV
    this is good to have around
    ProCharger F-1D
    Treadstone TR1235 FMIC
    Kooks 1 7/8 LTH
    Corsa catback
    New Era (228/240) cam
    Yella Terra 1.7 Rockers
    GMPP LS3 CNC heads
    Aeromotive A1000 fuel pump
    FAST fuel rails
    FAST FPR
    FIC 1000cc injectors
    Yank SS2800
    Camaro trans pan/filter
    Earl's trans cooler
    RX catch can
    EFI Live 736 RWHP/642 LBFT 91oct 15psi
    EFI Live 730 RWHP/621 LBFT E85 13psi
    EFI Live 695 RWHP/603 LBFT E85 11psi
    HP Tuners 762RWHP/646LBFT E85 9psi
  10. #30
    Too many projects.
    Detroit, MI
    So what are some good interior LED choices for the dome etc? I have bought some LEDs before and they were extremely dim / not as advertised. I'd rather not waste my money again on poor product.
    2009 Saab 9-3 Combi / 2.0T
