Will shorties work from a Camaro (L99, LS3) work on a L76? I know the DT shorties work on both. Im just wondering because there is so many options for the Camaro. I know LT's wont work.
09 Liquid red G8GT
8000k hid's
Inalfa sunroof
Rotofab cai & radiator cover
BT from 09.5
GXP fascia & diffuser
13.207@107.11
338 hp/337 tq
It begs the question: With so many excellent long tube headers with proven results, why would you consider shorties?
I already have Solo hfc's and I dont want to part with them.
09 Liquid red G8GT
8000k hid's
Inalfa sunroof
BT from 09.5
13.207@107.11
338 hp/337 tq
I am running the JBA Shorties on my G8GT. The G8 driver's side was rubbing on the steering shaft... they sent me a replacement and it was the driver's side from the Camaro. Based on this, I'd say at least the driver's side from the Camaro is the same.
-Todd...
with a little refab to you mach shorty you can reposition your cats back and still have the longtubes. I would imagine a good muffler shop could do it for about 200 bucks.
Pat G Tune & DOD cam, Rick C TB, LSA, Ported Heads, Circle D 2600 Stall
OBX Exhaust, SLP UDP,H&R springs, Koni Shocks
BP catch can, BMR Bushings/suspension/chassis
V Brembo's, Slotted/Drilled Rotors, 3.27s Gears
Bolt ons Street tires
12.649@107.817 60ft 1.96 Da 700ft
Heads/Cam pre stall Street tires
12.16@114.21 60ft 1.75 Da -200
After Stall
11.82@115.9 60ft 1.66 DA 400ft
Zex 125shot
11.48@124 60ft 1.83 DA 2000ft
