Any experience with these, on any car?
I had there LT's on my 97 cobra..No issue with them..Was pretty good..Issue was cobra its self..It was slow..lol
2014 Harley Davidson Street Bob-Vance and Hines Short Shot staggered.
2013 F150 Ecoboost- Loaded and stock.
Does BBK make them for G8's or just Camaro's?
09 Liquid red G8GT
8000k hid's
Inalfa sunroof
Rotofab cai & radiator cover
BT from 09.5
GXP fascia & diffuser
13.207@107.11
338 hp/337 tq
Fine print says they fit G8 also.
I just seen the fine print.............thanks.
09 Liquid red G8GT
8000k hid's
Inalfa sunroof
BT from 09.5
13.207@107.11
338 hp/337 tq
I've been researching the BBK shorties and from what I've seen on the Camaro forums is that with out a tune they lose a little bit in terms of peak but gain accross the midrange. That however is when they are mated to factory cats, so with your setup only a dyno tune would be interesting to see if that changes the gains. I would imagine you would have gains accross the board.
Pat G Tune & DOD cam, Rick C TB, LSA, Ported Heads, Circle D 2600 Stall
OBX Exhaust, SLP UDP,H&R springs, Koni Shocks
BP catch can, BMR Bushings/suspension/chassis
V Brembo's, Slotted/Drilled Rotors, 3.27s Gears
Bolt ons Street tires
12.649@107.817 60ft 1.96 Da 700ft
Heads/Cam pre stall Street tires
12.16@114.21 60ft 1.75 Da -200
After Stall
11.82@115.9 60ft 1.66 DA 400ft
Zex 125shot
11.48@124 60ft 1.83 DA 2000ft
