#PI0140: Grind, Growl or Moan Type Noise Heard from Front of Vehicle When Turning Steering Wheel - (May 25, 2010)
Subject: Grind, Growl or Moan Type Noise Heard From Front of Vehicle When Turning Steering Wheel
Models: 2008-2009 Pontiac G8
Condition/Concern
Some customers may comment on a grind, growl or moan type noise heard from the front of the vehicle when turning the steering wheel. This noise may occur when the vehicle is stationary or while driving and is more prevalent in low ambient temperatures (below 0°C (32°F)).
This condition may be caused by the interface between strut components that allows contact to occur, which results in a noise.
Recommendation/Instructions
Important: For a successful repair, the mount and bearing must be replaced together.
Replace the front strut mount and bearing on both sides of the vehicle. Refer to Front Suspension Strut Mount and Bearing Replacement in SI.
Parts Information
Part Number
Description
Qty
92249441
Bearing, Strut
2
92246856
Mount, Strut
2
92138863
Bolt, Front Suspension Strut
4
92138864
Washer, Front Suspension Strut
4
92138862
Nut, Front Suspension Strut
4
11588431
Nut (Stabilizer Shaft Link)
2
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E3927
Mount Assembly, Front Strut Bearing (Both) -- Replace
Use Published Labor Operation Time
For alignment times, refer to Labor Operation E2020 and add the applicable times to the regular labor hours.
