This is a special bulletin to introduce the 2011 Buick Regal. The purpose of this bulletin is to make you familiar with the vehicle's features and describe the action your Service Department will need to take to ensure that your dealership is able to fully service this vehicle.
ABOUT THE VEHICLE
The Buick Regal is a new midsize sport sedan for 2011. The Regal is based on GM's global front-wheel-drive architecture. Two models will be offered, the CXL and the CXL Turbo (Fall 2010).
Regal powertrains offer an impressive combination of horsepower, torque and fuel efficiency that make it ready to compete.
Engine
2.4L Naturally Aspirated DOHC SIDI 4-cylinder VVT ECOTEC Engine (RPO LAF)
• 182 horsepower (136 kW) @ 6700 rpm
• 172 lb ft (233 N·m) of torque @ 4900 rpm
• Estimated U.S. fuel economy of 20 mpg city and 30 mpg highway
• Canadian fuel efficiency of 10.8L/100 km (26 mpig) city and 6.5L/100 km (43 mpig) highway
2.0L Turbo DOHC SIDI 4-cylinder VVT ECOTEC Engine (RPO LHU) (Release Fall of 2010)
• 220 horsepower (164 kW)
• 258 lb ft (350 N·m) of torque @ 2000-4000 rpm
• Estimated U.S. fuel economy of 18 mpg city and 29 mpg highway
Transmission
2.4L Engine
Hydra-Matic® 6T45 six-speed automatic with Driver Shift Control (DSC)
2.0L Turbo Engine
• AISIN 40 six-speed automatic with Driver Shift Control (DSC)
• Available F40 six-speed manual
Chassis/Suspension
European-inspired ride, handling and steering that ensure the driving dynamics of a finely tuned sport sedan with the ride and comfort expected of a Buick.
• Independent MacPherson strut-type front suspension with dual-path mountings and hydraulic ride bushings
• Four-link independent rear suspension
• Specifically calibrated rack-and-pinion steering
• Large four-wheel disc brakes
• Anti-lock Braking System (ABS)
• StabiliTrak® Stability Control
• Traction Control System (TCS)
Body
Navigation System
The navigation system in the vehicle is not a touch screen system. It is controlled by using the radio-mounted Menu/Select knob (joystick inner and turn push knob outer ring), numbered preset buttons and other control buttons on the faceplate. Additionally, the console-mounted multifunction (turn/push) knob can also be used in conjunction with numbered preset buttons to control the navigation system.
The Menu/Select knob inner joystick can be pressed from side to side, up or down to move through the menus. The outer ring of the Menu/Select knob can be turned to move through menus and is pressed to enter a menu selection.
Some menus light up section tabs at the bottom of the screen. The corresponding numbered preset button can be pressed to make a corresponding tab selection.
Navigation Control Buttons
• RADIO BAND: Press to select the AM, FM, or XM band.
• HDD/DVD/AUX: Change to DISC, HDD, USB, or AUX by pressing HDD/DVD/AUX until the desired source is selected.
• Reverse/Forward: Previous or next radio station, track or file.
• 1-6 Preset Buttons: The preset buttons can be pressed to select the appropriate screen menu button function as shown on the display. For example press preset 6 to select the GO/List/Start buttons.
• NAV (Navigation): Press to view the vehicle's current position on the map screen. Continue pressing to cycle through the full map and split screen. Full Map displays the screen in full view; split screen displays both map and audio information.
• DEST (Destination): Press to plan a route through the Select Destination menu. If route guidance is active, press to access the Route menu.
• Power/Volume: Press to turn the system on and off. Turn to adjust the volume for the audio, OnStar®, voice guidance, and voice recognition voice prompts.
• INFO (Information): Press for Weather information (if equipped) and climate control displays (if equipped).
• DEL (Delete): Select to delete a song from the hard drive. To delete an entire list of Artists, Albums, or Genres, select the category from the HDD Music Menu screen.
• REC (Record): Press to record a CD, MP3, and USB to the hard drive.
• AS (1/2) (Automatic Store): Press to select the automatic store list. Press and hold to automatically save a list of 12 stations with the strongest signal strength. AM or FM Band press AS (1/2) to display stored list. Press corresponding preset number to select desired station.
• FAV 1/2/3 (Favorites): Press the FAV button to open a favorite list or to switch to another favorite list.
• TONE: Press to access the Sound screen to adjust bass, midrange, and treble. (Use the Menu/Select knob or multifunction knob (if equipped) to make adjustments.)
• Multifunction Knob: Turn to navigate through the system's display window and to highlight an option. Press the outer ring to activate/select the highlighted option.
• CONFIG (Configure): Press to adjust features for radio, navigation, display, phone, vehicle, and time.
• BACK: Press to return to the previous screen in a menu. The BACK button does not work in primary display screens, such as phone, sound settings, configure settings, info screens, map screen, or audio screen.
• RPT NAV (Repeat Navigation): Press to repeat the last voice guidance prompt.
Navigation Settings
The navigation menu screen accesses the navigation system settings.
To access:
•Press the CONFIG control button to display the Setup menu.
•Press the CONFIG control button until the navigation menu displays.
•Select the navigation setting to change.
Multifunction Knob
The multifunction knob on the center console provides access to navigation, audio and phone functions.
• Press the appropriate button to access the desired menu or function.
• Turn the knob to highlight the desired option.
• Press the knob to select the option.
Vehicle Personalization
The audio system controls are used to access the personalization menus for customizing vehicle features.
CONFIG (Configuration): Press to access the Configuration Settings Menu.
MENU/SELECT Knob: Press the outer ring of this knob to enter the menus and select menu items. Turn the knob to scroll through the menus.
BACK: Press to exit or move backwards in a menu.
Entering the Personalization Menus
•Press CONFIG to access the Configuration Setting menu.
•Turn the MENU/SELECT knob to highlight Vehicle Settings.
•Press the outer ring of the MENU/SELECT knob to select the Vehicle Settings menu.
The following list of menu items will be available:
• Climate and Air Quality
• Comfort and Convenience
• Collision/Detection Systems
• Languages
• Lighting
• Power Door Locks
• Remote Lock, Unlock, Start
• Return to Factory Settings
Audio/Bluetooth Steering Wheel Controls
Volume: Press + or - to increase or decrease the volume.
Next/Previous: Rotate up or down to go to the next or previous favorite radio station, CD track, or MP3 file.
SRC Source: Press to select an audio source.
Push to Talk: Press to interact with the OnStar®, Bluetooth® or navigation system.
End Call/Mute: Press to end or reject an OnStar® or Bluetooth® call. Press to mute the vehicle speakers.
Bluetooth
Bluetooth® wireless technology is a short-range communications technology intended to replace the cables connecting portable and/or fixed devices while maintaining high levels of security. Only vehicles with steering wheel controls will have Bluetooth® functionality. In order to utilize the vehicle’s Bluetooth® system, a Bluetooth® equipped cellular phone is required.
With Bluetooth® technology customers can experience hands-free calling as their Bluetooth® capable cellular phones are wirelessly connected to the vehicle. It will allow customers to place and receive calls using the steering wheel controls and voice recognition. The vehicle audio system will allow you to listen to your call through the vehicle speakers and adjust volume through steering wheel or radio controls.
Not all Bluetooth® cellular phones are guaranteed to work with the vehicle’s Bluetooth® system. Based on the cellular phone’s service provider and the manufacturer’s implementation of Bluetooth®, not all phones support all available Bluetooth® functionality. Bluetooth® enabled cellular phones will be tested for vehicle compatibility and a feature compatibility list will be provided via the GM Bluetooth® website: http://www.gm.com/vc/bluetooth/
Portable Audio Devices
A USB port (1) and a 3.5 mm auxiliary input jack (2) are located in the storage compartment of the center console.
• A portable device connected to the auxiliary input jack can be controlled only by using the portable device controls. To optimize speaker volume, fully increase the volume level of the portable device.
• Compatible devices connected to the USB port can be controlled by the audio system. Not all devices may be supported. Use the MENU/SELECT knob and the audio steering wheel controls to access various functions.
120 Volt Power Outlet
The power outlet is located on the rear of the center console.
An indicator light on the outlet comes on when in use. The light comes on when the ignition is in ON/RUN and equipment requiring less than 150 watts is plugged into the outlet and no system fault is detected.
If you try to connect equipment using more than 150 watts or a system fault is detected, the equipment may operate for a short period and turn itself off. A protection circuit shuts off the power supply and the indicator light turns off. To reset the circuit, unplug the item and plug it back in or turn the Remote Accessory Power (RAP) off and then back on.
Transportation Mode
The Regal is delivered to the dealership in Transportation Mode. Be sure to disable Transportation Mode before delivery of the vehicle to a customer to avoid unnecessary customer concerns and warranty expenses.
Transportation Mode is designed to extend the battery charge of a vehicle during shipment or during extended storage. When activated, it shuts down modules and accessories that do not effect FMVSS requirements. Modules in power reduction hibernation will vary depending on how the vehicle is equipped, and may include HVAC afterblow, lighting timers, content theft system and LED, radio, chime module, suspension control module, RFA and others.
The vehicle may be started and driven in Transportation Mode but will have reduced functionally.
How to Change Modes
•Press and hold the brake pedal.
•Press the hazard warning flasher button.
•Start the engine.
•Turn the ignition key to crank mode and hold for 15 seconds.
When active, Transport Mode is On will display on the DIC and the red battery light will flash. When being deactivated, the Transport Mode is Off will display on the DIC and the red battery light will stop flashing.
Interactive Drive Control System (Available on Turbo Models Only in Fall of 2010)
The interactive Drive Control System adapts to the driving style and preference of the driver within one of the three driving modes. It automatically adapts to the driver's style in the Standard mode or adjusts chassis behavior based on modes selected by the driver -- Sport or Tour.
Standard -- Use for normal city and highway driving. This mode is active each time the vehicles is started.
Tour -- Press the TOUR button for a smooth ride during long distance highway driving.
Sport -- Press the SPORT button when road conditions or personal preference demand more responsive, controlled handling. The Sport mode setting can be changed in the Vehicle Personalization menu by using the audio system controls.
When the Sport and Tour modes are turned off, the system returns to the Standard mode.
Driver Shift Control allows the driver to shift gears manually. This feature can be used to drive the vehicle in a sportier manner or to downshift when driving on a downhill grade to provide engine braking. Move the shift lever to the left of Drive. Then tap forward to upshift and rearward to downshift. If the vehicle speed is too high or too low for the requested gear, the shift will not occur. When coming to a stop, the transmission will automatically downshift.
Electronic Parking Brake
The Electric Parking Brake has a switch in the center console, which takes the place of the manual parking brake system, the foot pedal and release handle. To apply the parking brake momentarily lift up on the electric parking brake switch, once applied the red brake light will turn on. To release the electric parking brake, turn the ignition switch to the ON or RUN position, apply and hold the brake pedal, and push down momentarily on the electric parking brake switch. When the parking brake is released the red brake light turns off.
Rear Parking Assist (Audio Only)
Detected objects are indicated by audible beeps when the vehicle is in Reverse. The interval between beeps becomes shorter as the vehicle gets closer to an object. When the distance is less than 30 cm (12 in), the beeps are continuous. The system operates only at speeds less than 8 km/h (5 mph).
To turn the system on/off, press the Parking Assist button on the center of the instrument panel.
Power Door Locks
Press the power door Unlock/Lock button in the center of the instrument panel to unlock or lock all doors.
Power Windows
All windows have express-down. Only the front window have express-up.
Keys
Due to the uniqueness of the Regal ignition/door lock key, special equipment is required to cut a key. If you do not have the required equipment, a cut/coded key can be ordered through GMSPO. Refer to Corporate Bulletin Number 09-00-89-029D (Key Cutting Procedure for Obtaining Replacement Key) for additional information. The remote control transmitter and the key shank are not serviced separately.
Unique Vehicle Characteristics
Locking Fuel Door
The fuel door will not open or close if the vehicle is locked.
• To open the fuel door, press the center of the rear edge of the door. It will pop open slightly. Pull the door open.
• To close the fuel door, push the door until it latches and is flush with the side of the vehicle.
Trunk Release
There is no trunk release button inside the vehicle. To open the trunk, press the release button on the Remote Keyless Entry (RKE) transmitter or press the touchpad under the vehicle emblem.
Low Fuel Message/Indicator
The low fuel indicator turns on promptly at 64 km (40 mi) remaining, then the next time it turns on is at 40 km (25 mi). A Low Fuel message will also be displayed in the DIC at these intervals. At the 40 km (25 mi) interval, the DIC will not allow you to acknowledge that function. You cannot scroll through to any other information to be displayed. It does count down from 40 km (25 mi), but stays on the DIC screen.
