**RIP Shaun Finley**
FUCK CANCER
**RIP Charlie**
'16 2SS NFG Camaro M6 NPP Mag
Does this feel like when you step on the gas it shifts but takes a little bit? It dont feel like it revs like a slip but tach's out alittle higher
GTO spares and jack kit 200 OBO
rear 17x9.5 rims 200 OBO
Mine has this problem, I took it to the dealer to get fixed (I referenced this bulletin) and I still have the problem to this date. My trans problems got a bit worse, as when the trans is cooler, it will slam into 2nd gear, then flare from 2-3. The slamming into 2nd gear, all depends how much gas you give it. I had it slam so hard a few times, that I thought it was going to break.
I'm unable to get it to duplicate 100% of the time, so my dealer said bring it in when it happens more constantly. The 2 or 3 times I got it to happen w/ a Trans tech in the car, he either wasn't paying attention or said I lifted off the gas, causing the flare.... which is 100% pure BS.
mine is doing something like this. It just will not shift when it is cold. I did have this problem before my TCM tune. I guess that flash cable will be worth the extra $ spent.
when they fix this as long as the TCM is not changed I can just flash my tune back in?????
if TCM is changed then I have to read and send new TCM info to Kirk????
I rock this issue too. I think this TSB came out beacuse of my car lol.
Don't Hassle The Hoff!
Well i put my stock tune back in yesterday and the car will bark the tires with the bone stock tune. It still has the flare and the harsh shifts so I am thinking they will be pulling my transmission and replacing the seals in mine today along with the rear main seal repair.
2009.5 G8 GXP SRM A6
Performance Mods - Rotofab CAI, Underpanel mod, 160° thermostat, Powerbond UDP, Resonator and Secondary cat delete, x-pipe, and HP Tuners tuned.
Suspension mods - BMR front radius rod bushings, diff bushings, and cross member bushings.
Dyno #'s - 361rwhp / 359rwtq
Mine had the flare when cold. No amount of tuning could cure it. I had the dealer replace the seals and it is 100% fixed. I love it!
