Vehicle Information
VIN: 6G2EP57W09L306191 Model: 2EP69-2009 G8 GXP
Service Contract: No Branded Title: No Warranty Block: No PDI Status: Yes
Order Type: 70 - RETAIL - STOCK
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Noncompliance Recall A090101 09101 TIRE PRESSURE MONITOR SYSTEM - REPROGRAM REQUIRED 05/25/2009 Closed
Service Update Bulletins A090076 09076 SERVICE UPDATE-INV & CUST VEH.- IP CLUSTER REPROG - EXPIRES WITH BASE WARRANTY 05/21/2009 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677 Canada) and in the USA:800-556-3600.
OnStar Equipped: Y OnStar Status: Inactive
XM Equipped: Y XM Radio ID: 7MZA11R0 XM Status: Inactive
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Warranty Add Date Start Date Effective Odometer End Date End Odometer
Bumper to Bumper Limited Warranty 05/31/2011 03/06/2009 21 MI 03/06/2012 36,021 MI
Corrosion Limited Warranty 05/31/2011 03/06/2009 21 MI 03/06/2015 100,021 MI
Emission Limited Warranty 05/31/2011 03/06/2009 21 MI 03/06/2012 50,021 MI
Emission Select Component Ltd Wty 05/31/2011 03/06/2009 21 MI 03/06/2017 80,021 MI
Powertrain Limited Warranty 05/31/2011 03/06/2009 21 MI 03/06/2014 100,021 MI
Emission Select State Component Lty Wty 05/31/2011 03/06/2009 21 MI 03/06/2016 70,021 MI
Special Coverage 10283 05/31/2011 03/06/2009 21 MI 03/06/2019 120,021 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
02/24/2011 542727 ZREG----Regular Vehicle Transaction K2756 - Synchronizers - 3rd-4th - R&R Or Replace 21,277 MI
02/14/2011 542046 ZREG----Regular Vehicle Transaction C6585 - Cover, Reclining Seat Back Control Hinge - Driver - Outer - R&R Or Replace 21,032 MI
02/14/2011 542046 ZREG----Regular Vehicle Transaction K2780 - Reverse Gear Synchronizer Replacement 21,032 MI
02/14/2011 542046 ZREG----Regular Vehicle Transaction E3021 - Springs, Front Coil - Left - Replace 21,032 MI
12/07/2010 538089 ZREG----Regular Vehicle Transaction C2320 - Instrument Panel Upper Trim Panel Replacement - Right Side 18,993 MI
12/07/2010 538089 ZREG----Regular Vehicle Transaction B2842 - Guide, Sunroof Sliding Panel Side - Both - R&R Or Replace 18,993 MI
07/01/2010 126123 ZREG----Regular Vehicle Transaction C6585 - Cover, Reclining Seat Back Control Hinge - Driver - Outer - R&R Or Replace 12,497 MI
07/01/2010 126123 ZREG----Regular Vehicle Transaction C2821 - Carpet And/Or Pad, Console Side Trim - Left - Replace 12,497 MI
02/12/2010 813279 ZREG----Regular Vehicle Transaction Z2080 - ROADSIDE SERVICE (TOWING) 9,400 MI
12/04/2009 119017 ZREG----Regular Vehicle Transaction J0720 - Crankshaft Balancer Replacement 7,601 MI
12/04/2009 119017 ZREG----Regular Vehicle Transaction Z5001 - VIP FREIGHT/POSTAGE REIMBURESEMENT 7,601 MI
12/04/2009 119017 ZREG----Regular Vehicle Transaction R2972 - Key, Theft Deterrent System - Replace 7,601 MI
12/04/2009 119017 ZREG----Regular Vehicle Transaction Z7904 - 4-DAY COURTESY TRANSPORTATION 7,601 MI
10/26/2009 117807 ZREG----Regular Vehicle Transaction K0800 - Clutch Assembly Replacement 7,195 MI
10/26/2009 117807 ZREG----Regular Vehicle Transaction Z7905 - 5-DAY COURTESY TRANSPORTATION 7,195 MI
10/25/2009 568741 ZREG----Regular Vehicle Transaction Z2080 - ROADSIDE SERVICE (TOWING) 108 MI
09/25/2009 116657 ZFAT----Field Action Recall V2084 - 09076 - Reprogram Instrumental Panel Cluster 6,184 MI
09/25/2009 116657 ZFAT----Field Action Recall V2083 - 09101 - Tire Pressure Monitor Sensor Learn 6,184 MI
09/25/2009 116657 ZREG----Regular Vehicle Transaction N6636 - Entry Control Systems Wiring and/or Connector Repair or Replacement 6,184 MI
01/29/2009 A06191 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 MI
