Results 11 to 20 of 25
Thread: PIP4765: Engine Misfire And No Compression Due To Piston Damage
    Banned
    Jan 2009
    Chicagoland
    It says they are:
    •Inspect for aftermarket components, such as an exhaust, ignition, high performance air filter (K and N style), or air intake system. Take photos and document accordingly if anything is found.
    Edited by Wicked: I suppose I should read the bulletins, huh?
    HAHAH.
    Addicted Member JVH1982's Avatar
    Lockport, IL
    Not a mechanic or a tuner, but, I am in agreement with the line of thought that an intake, exhaust, and a tune to compensate for those things (reasonable timing advance, MAF/IAT tables, etc.) is not gonna blow a hole in a piston.
    On that note, what kind of "Radical Tune" (with regards to timing) would it take to do this?
    2009 White Hot GT, Sport/Premium Pkg. w/ Onyx-Red Interior
    Vararam, Kooks Mids w/ Cats, and custom tune from Modern Muscle
    WeatherTech Floorliners, GM/Pontiac Trunk Liner
    "Pilots are a different type of people." ~ Most Psychologists
    Banned
    Jan 2009
    Chicagoland
    An extremely lean condition can cause a piston to melt, and timing that is too far advanced can cause a piston to chip.
    Lockport, IL
    Quote Originally Posted by DRCUSTOMPARTS View Post
    Thanks for the info.
    Thanks Wicked! You're doing a great job IMO.
    Chris
    Jun 2013
    I just found out the cylinder 1,3,5,7 is misfiring badly and o2 sensor bank 1 is causing check engine light to come on, would that make my g8 pistons bad
    Jun 2013
    This problem happen two weeks ago, but it stop after I removed the throttle body and clean it, and now it started again
    Quote Originally Posted by American muscle View Post
    Did u have O2 replaced?
  9. #19
    Jun 2013
    No I have not replace the o2 sensor
  10. #20
    Jun 2013
    Does anyone knows where the stability control module is located
