Results 1 to 6 of 6
Thread: PIP4158C: Low Oil Pressure
    SoCAL
    Default PIP4158C: Low Oil Pressure
    PIP4158C: Low Oil Pressure Due To Seized Oil Pressure Relief Valve - (Dec 29, 2009)
    Subject: Low Oil Pump Pressure due to Seized Oil Pressure Relief Valve
    Models: 2008-2009 Buick Lacrosse, Allure (Canada Only)
    2007-2010 Cadillac CTS-V, Escalade
    2007-2010 Chevrolet Avalanche, Corvette, Silverado, Suburban, Tahoe
    2007-2008 Chevrolet Monte Carlo SS
    2007-2009 Chevrolet Impala SS, Trail Blazer
    2009-2010 Chevrolet Colorado
    2010 Chevrolet Camaro
    2007-2010 GMC Envoy, Sierra, Yukon
    2009-2010 GMC Canyon
    2008-2010 Hummer H2
    2008-2010 H3 Alpha
    2008 Pontiac Grand Prix GXP
    2008-2010 Pontiac G8 GT <~~~LOL @ the typo!
    2007-2009 Saab 97x
    with the Following Aluminum V8 Engine RPOs:
    L76, L77, L92, L94, L99, L9H, LC9, LH6, LH8, LH9, LS2, LS3, LS4, LS7, LS9, LSA, LZ1
    Condition/Concern:
    Some customers may complain of low oil pressure, no oil pressure, and/or engine noise, which may be the result of a sticking oil pump pressure relief valve. In some instances, this may occur intermittently if the valve frees up when the engine cools down.
    Recommendation/Instructions:
    If SI diagnosis isolates low mechanical oil pressure at the oil filter housing and oil pressure sensor, replace the oil pump, flush the oil cooler lines (if equipped), clean the inside of the oil pan, change the oil and filter, and re-evaluate the concern.
    Notice: If an engine noise is noticed after replacing the oil pump, follow the SI diagnosis and repair the engine as necessary.
    Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
    GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for infor
    **RIP Shaun Finley**
    FUCK CANCER
    **RIP Charlie**
    '16 2SS NFG Camaro M6 NPP Mag
    Senior Member BluYa76's Avatar
    Feb 2009
    Manassas, Virginia
    Ahhh boy what next . Thanks for posting and I'm glad I've got a gauge to watch my oil pressure with.
    Tim
    2009 PSM GT Fully Loaded
    GM Sirius Connect SIRGM2L - INSTALLED (No more XM!!!)
    Fasterproms Ported Intake Manifold w/LS3 TB
    Camaro Brembo Brakes @ all 4 corners
    Complete GXP Suspension Swap
    GXP Axle-Back Exhaust w/x-pipe
    Hacked Atari 3 Gauge Display
    Superchips Cortex Tuned
    Vararam Ram Air Intake
    OEM Bluetooth Add-on
    BMR Front Swaybar
    HSV Valve Covers
    20" Camaro Rims
    Vector HSRK
    6k HID's
    SoCAL
    I am posting ALL G8 bulletins, there are quite a few. Most are not specific to only the G8 or the L76. Just because it has a bulletin doesn't mean its a general problem, like this one, it CAN affect any of the vehicles listed above.
    FUCK CANCER
    **RIP Charlie**
    THANK YOU for doing this mom !
    Feb 2011
    I have had this on 2 different motors 1st. At 205,000 miles and a new motor with 60,000 miles lost both. No one said anything about this.
    Quote Originally Posted by Mikeg8 View Post
