Page 1 of 5 123 ... LastLast
Results 1 to 10 of 45
Thread: PIC5283, Water leak in Passenger compartment
    SoCAL
    Default PIC5283, Water leak in Passenger compartment
    #PIC5283: Water Leak Into Passenger Compartment From Rear Doors - keywords wet - (Nov 20, 2009)
    Subject: Water leak into passenger compartment from rear doors
    Models: 2008-2009 Pontiac G8
    Condition/Concern:
    Some customers may comment about water found on the interior of the vehicle near one of the rear doors.
    Recommendation/Instructions:
    If a customer comments about a water leak in the rear of the passenger compartment and you have it narrowed down to the front of one of the rear door seals, follow the procedure listed below.
    Locate the area of the door seal pictured below.
    There is a rubber plug that is part of the door weather stripping (pictured below). This rubber plug is meant to keep water from falling off of the roof and funneling down into the door.
    Pull the weather stripping back to expose the body. Fill the void with silicone sealer in the areas with the arrows as pictured below.
    The silicone should be in the areas pictured below.
    Allow the silicone to dry then reinstall the weather-stripping making sure to properly position it in place. Retest for water leaks to confirm the vehicle is repaired.
    Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
    GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer
    **RIP Shaun Finley**
    FUCK CANCER
    **RIP Charlie**
    '16 2SS NFG Camaro M6 NPP Mag
    Dec 2009
    Southern New Jersey
    Thank you for the information!
    Cheri P
    2009 Pontiac G8 GT Maverick Silver Metallic - Auto, Mods: Magna flow exhaust
    Central Florida
    Please post the pics!
    SoCAL
    Nope... they are waaaaaaaay to consuming to do from work... (I am not even supposed to be on the interwebz) if someone needs em, I suppose I can do them from home... but tell me what ya need please
    FUCK CANCER
    **RIP Charlie**
    Central Florida
    Would like to see the pics for the first one if possible?
    WNY
    Yeah, you can atleast post these these pics... and I'll give you a pass on the others for winning
    2009 SBM G8GT (Garage Queen)
    SoCAL
    Pictures added... can a mod move this to the TSB section...
    FUCK CANCER
    **RIP Charlie**
    VIP Member vert's Avatar
    Nov 2008
    Indiana
    Thanks Wicked, what would we do without you.
    SoCAL
    now that I have a lil more time on my hands.... here is another
    #09-01-39-007: Carpet Wet When A/C Is On (Realign A/C Drain Tube) - (Aug 7, 2009)
    Subject: Carpet Wet When A/C Is On (Realign A/C Drain Tube)
    Models: 2008-2010 Chevrolet Caprice, Lumina (Middle East Only)
    Condition
    Some customers may comment that when the A/C is on, they feel moisture on the front floor carpet.
    Cause
    Example of a Collapsed A/C Drain Grommet
    This condition may be caused by a collapsed A/C drain grommet (1), resulting in a wet carpet condition.
    Correction
    Remove the panels in order to gain access to the A/C drain pass-thru grommet and realign drain tube using the procedure listed below.
    1. Verify the customer condition.
    2. Remove the insulator panel (1). Refer to Instrument Panel Insulator Panel Replacement - Left Side in SI.
    3. Remove the knee bolster (2).
    • Grasp the knee bolster assembly (2) and carefully pull downward to disengage the retaining clips.
    Important: When removing the knee bolster, care must be taken not to scratch the steering column cover. This can be achieved by slightly bending the knee bolster to avoid contact with the steering column.
    • Disconnect the headlamp switch electrical connector from headlamp switch.
    4. Remove the center console extension panel.
    5. Remove the console trim plate (LHD) (1).
    6. Push the carpet down with one hand, and with the other hand, take a pick tool and insert the tool in the grommet.
    Important: When installing the HVAC drain tube and grommet, make sure they are properly aligned in order to allow the HVAC water to drain properly.
    7. Route the pick around the rubber HVAC drain grommet and make sure the drain tube is properly centered in the grommet. View the figure above and note how the HVAC drain tube grommet is positioned. The lip of drain grommet should be positioned inward of the entire circumference (1).
    8. Reinstall all of the panels.
    9. Let the vehicle run with A/C on.
    10. Perform a final inspection for the A/C and verify that the system is draining properly.
    Warranty Information
    For vehicles repaired under warranty, use:
    Labor Operation
    Description
    Labor Time
    D9755*
    Reinstall the HVAC Drain Grommet & Make Sure HVAC Drains
    0.4 hr
    *This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide
    FUCK CANCER
    **RIP Charlie**
    Central Florida
    Thanks much!
