Page 5 of 5 FirstFirst ... 345
Results 41 to 45 of 45
Thread: PIC5283, Water leak in Passenger compartment
  1. #41
    Bothell, WA
    Quote Originally Posted by TurboMike View Post
    No sunroof. Water is INSIDE the door. Not getting into interior of car. I've looked for the "drain holes" but there are only three holes for trim pops. Water should not be getting into the door as others have said.
    Same issue - water getting into my rear passenger door - wiring is starting to corrode. Not into car, but into door - would love to see pics.
    2009.1 Pontiac G8 GT
  2. #42
    Jan 2010
    Ugh after Trop Storm Arthur now I'm getting water in my front pass door too. I just stick a pen cap in the door trim until it all drips out. I might just cut one of the clips out, or drill a drain hole next to the trim and let it drip out as a short term solution.
    Anyone know how I can get these TSB pics??
  3. Thanks Hahano404 thanked for this post
    Likes Hahano404 liked this post
  4. #43
    Boardman, Ohio
    Pictures that can be added to first post.
    #PIC5283: Water Leak Into Passenger Compartment From Rear Doors - keywords wet - (Nov 20, 2009)
    Subject: Water leak into passenger compartment from rear doors
    Models: 2008-2009 Pontiac G8
    Condition/Concern:
    Some customers may comment about water found on the interior of the vehicle near one of the rear doors.
    Recommendation/Instructions:
    If a customer comments about a water leak in the rear of the passenger compartment and you have it narrowed down to the front of one of the rear door seals, follow the procedure listed below.
    Locate the area of the door seal pictured below.
    There is a rubber plug that is part of the door weather stripping (pictured below). This rubber plug is meant to keep water from falling off of the roof and funneling down into the door.
    Pull the weather stripping back to expose the body. Fill the void with silicone sealer in the areas with the arrows as pictured below.
    The silicone should be in the areas pictured below.
    Allow the silicone to dry then reinstall the weather-stripping making sure to properly position it in place. Retest for water leaks to confirm the vehicle is repaired.
    Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
    GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer
  5. Thanks Hahano404 thanked for this post
  6. #44
    Fixed.
    Under more construction.
  7. #45
    Bothell, WA
    Thank you!!!
