Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 45
Thread: PIC5283, Water leak in Passenger compartment
  1. #31
    Well put me into the list as well. My rear floor weels were a little surface damp. I pulled the rear seat and the jute was dry. I check the AC drain and mine is installed correctly. I went ahead and put the silicon into the rear door seals. If this does not get it then I will take it in for the sunroof TSB next.
    2009.5 G8 GXP SRM A6
    Performance Mods - Rotofab CAI, Underpanel mod, 160° thermostat, Powerbond UDP, Resonator and Secondary cat delete, x-pipe, and HP Tuners tuned.
    Suspension mods - BMR front radius rod bushings, diff bushings, and cross member bushings.
    Dyno #'s - 361rwhp / 359rwtq
  2. #32
    Senior Member smso966's Avatar
    Louisiana
    Add me as well. Found it today after the car had been sitting for over a week. The rear passenger's floor mat was covered in white black, and green mold on the corners and under on the backing. I found that it was my rear door seal leaking after a hose test. Fixed myself per TSB. Now how to get rid of the mold and odor?
    DD: 08 White Hot G8 GT Best E.T. 12.698 @ 109.1 MPH
    VMR 20's 4 Wheel 04 CTS-V Brembo's
    FE3 & Eibach, Roto Fab,Doug Thorley LTs Magnaflow
    1 of 1,086 2008 White Hot Pontiac G8 GT's
    Garage Queen:
    09 Stryker Blue G8 GT (No ET Under construction)
    TVS1900, GXP 19's, 4 Wheel 09 CTS-V Brembo's
    Rotofab, Solo, More to come soon!
  3. #33
    Senior Member BLKG8's Avatar
    Dealer replaced the carpet and padding once they seen mold, and knew it had been caused by the known water leak.
    They also replaced all of the door speakers and window seals. Speakers got wet too. Doors are made to take water and drain threw the bottom. But on my car it would trickle onto the speaker and into the car.
    ________________ _
    '08 G8... Panther Black
    Premium & Sport Pkg.- 7/08
  4. #34
    New York
    I just checked my car out to see about this leak and my rear passenger side rug is damp. (2009 G8 GXP) I will be bringing it to the dealer next week, thanks for the tsb.
  5. #35
    By Marion, Mississippi
    I don't even want to talk about it.
    Just Sitting The Bench Now
  6. #36
    Addicted Member Adam's Avatar
    Eighty Four, PA
    Mine was "fixed" but will be going back in for the same issues again. I checked right after I got out of the dealer but not really since. Now I removed the winter floor mats with my mats below. I took the mats out to vacuum them and noticed both mildew and mold in the same spot as the previous leak. No one even sat in the back all winter. Not once! So I would say the issue is back if it ever got resolved in the first place. It will be going back in for that one.
    Don't Hassle The Hoff!
    http://ohiorides.org/forum/attachment.php?attachmentid=167&d=1314562258
  7. #37
    Jan 2010
    These pics wont load anymore. I'm getting a ton of watr in my door but cant figure out where to silicone. Anyone know another site to look at the TSB pics?
  8. #38
    Member AuuuSSSIII YA' LATA's Avatar
    Sep 2013
    Philly
    Which door? Do you have a sunroof? Is water running down your a-pillar?
    Sent from my HTC6435LVW using Tapatalk
    09 gt aka "Zeus"
    Vararam, Solo shorty exhaust, diablo tune(no longer)....... PAT G TUNE!! , GXP diffuser, eibach pros, fe3 shocks/struts
  9. #39
    Senior Member JoshHefnerX's Avatar
    Glendale, Az
    Seriously though can the pics be reposted?
    Josh
    '09 GT White - Vararam, HID's, a catch can and BMR sways so far.
    '67 Firebird 400 4-spd - not stock.
    05 Dodge Ram
    05 Yamaha FJR1300
    94 Kawasaki KLR650
    http://www.fuelly.com/driver/JoshHefnerX/g8
  10. #40
    Jan 2010
    No sunroof. Water is INSIDE the door. Not getting into interior of car. I've looked for the "drain holes" but there are only three holes for trim pops. Water should not be getting into the door as others have said.
