Big thanks goes to 08G8V8 (Jeff) for the use of his garage and a second set of hands.
To help speed up the install you'll need the following:
1) Socket wrench set with at least a 10 MM deep socket in addition to the standard metric sockets
2) Wrench, 10 MM - small (short handled)
3) Torx set - T-25 or T-27 (we didn't note this in the install, another poster told me it was a T-27)
4) Flathead screwdriver
5) Phillips head screwdriver
6) Recommend something to protect the fender - or make sure that you aren't wearing pants with rivets, metal belt buckle, etc. etc.
Allocated 45 to 60 minutes for install time. These instructions were based on the install of a 2009 G8 GT, 9L1 car. Directions can vary slightly depending on the production date of your G8.
STEP 1:
The first step is to separate the upper and lower sections fo the factory cold air intake.
This is accomplished by opening up five clips located on the stock airbox. These clips allow easy access to the stock air filter for inspection and replacement. The next two pictures show two of them, after the clips have been released. There are four visible clips, that are opened simply by pressing on them with your thumb. The fifth can't be seen. It is located under the Mass Airflow Sensor (MAF) - which is the long black tube coming out of your airbox toward the engine. Feel under the MAF along the airbox and you'll find the fifth clip. You have now freed the top section from the bottom section.
You can see the air filter exposed in this picture. Lift the top part of the factory cold air intake up just enough to remove the filter, set aside.
STEP 2:
Next, you're going to disconnect the MAF wiring harness. This is done simply by squeezing the harness at its base, may take a bit of wiggling, squeezing, to find the right spot.
STEP 3:
Next, you're going to disconnect the factory breather hose from both the factory cold air intake and the engine. This is a plastic tube located close to the intake on the engine. This is removed by rotating the outer ring attached to the tubing. Again, may take a bit of turning, wiggling to get it right for someone doing a first time install.
Once you've disconnected the breather hose from the factory cold air intake, follow the hose back to the engine. It ultimate connects to the PCV under the heater hoses that run on top of the engine. The connection is covered with a piece of brownish insulation. Simply grab the base of the connection, insulation and all and pull with a firm steady pressure until it slips off.
CONTINUED IN NEXT POST...
