Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: TB/Intake Manifold Removal
    Quote Originally Posted by G8GTKID View Post
    Is the fuel pressure gage and the adapter absolutley neccessary for the fuel pressure relief procedure....? If not, how can I do this without having to get these...?
    Thanks
    Not necessary. Every instruction has to be made idiotproof these days.....but they keep making better idiots.
    On the front left of the fuel rail is a black plastic cap, unscrew the cap and underneath is a small shrader valve.
    If you can let the air out of a tyre without killing yourself, then you can work out how to de-pressurise the fuel rail also.
    VIP Member G8GTKID's Avatar
    Oct 2010
    Indianapolis, IN
    Well said!! lol
    Thanks CP!
    Vararam CAI w/ HSRK, Stage 1 Ported Throttle Body/Intake Manifold, and a Mike Norris Catch Can
    Senior Member RamJet's Avatar
    Boerne, TX
    How do I separate the injector connectors? It just says to do it, but I can't find the release mechanism.
    Thanks.
    2008 G8GT, Panther Black
    Mods: Pat G Spec'd Cam, PAC 1518 Springs, Trick Flow 7.4 Hardened Pushrods, Pace DoD Delete Kit, Comp Trunion Upgrade, GRRRR8 Heater Hose Relocation Kit,
    ARH 1 7/8" Long Tubes Cats & Exhaust, Spectre CAI, Pat G Dyno Tune
    412hp/396tq at the wheels
    Best 1/4 Stock: 13.6 @ 102
    Best 1/4 Modded: 12.49
    2008 G8 GT, Magnetic Gray, Two-tone Leather Interior, Sunroof, Bremmer Wheels,
    Her Best To Date: 14.0278 @ 101.49 w/ a .0598 R/T!
    New R/T Best of .0005 2/22/2012
    SoCAL
    Default Re: TB/Intake Manifold Removal
    Quote Originally Posted by RamJet View Post
    Thanks.
    It's kinda hard to explain. Pull up on the center tab then you push down on the outer part and release it up...i think.
    sent from my Note2 using Tapatalk
    **RIP Shaun Finley**
    FUCK CANCER
    **RIP Charlie**
    '16 2SS NFG Camaro M6 NPP Mag
    Boerne, TX
    Quote Originally Posted by WickedMom View Post
    Thank you, Wicked Mom. These drivers-side ones are a bear!
    Hopefully the rest of this cam swap goes better, just trying to get all of this electrical and vacuum crap out of the way sucks!
