Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 52
Thread: UPR Billet Oil Catch Can
  1. #21
    WNY
    Quote Originally Posted by FB3 View Post
    Will this work on a GXP? I have read that the GXP breathing/pvc locations are different than the GT.
    Would love to get one, but don't want to run into an installation problem.
    Yes, It will work with the GXP 99-LS1-SS has his on a GXP. He might even have some pics posted on his install.
    2009 SBM G8GT (Garage Queen)
  2. #22
    Beyond Help Call-Me-D's Avatar
    Houston,Tx(Clear Lake)
    Quote Originally Posted by wagon540 View Post
    Nice, are those o ring or pipe thread fittings? Just curious, i'm gonna use braided line on mine, it should be here in a couple of days.
    They are 3/8 npt fittings....I just finished installing, took 20 minutes and the install is clean......Pics to come later.
    Wagon, When I get some free time, I'm gonna switch to AN fittings and the black "Pro-lite" nylon braided hose to make it even cleaner.
    Speed costs money. How fast do you wanna go?
    Daniel
    My Beaters:
    09 White-Hot G8 GT(FOR SALE)
    2011 Ecoboost F150
    2011 Star Stryker
  3. #23
    Monmouth Illinois
    Quote Originally Posted by Call-Me-D View Post
    Thanks, i said braided, i meant earls pro lite 350. Might even weld an AN male fitting on the inlet plate tube, and drill and tap intake. Haven't looked to see if thats feasible yet. Hopefully have it and other stuff to work on this weekend.
    08 IOM GT 20x8.5 20x10 Breytons GTS, 1 7/8 Kooks, 3'' custom exhaust with side exit and cutouts all ceramic coated. 3600 Yank, 3.90 gears. Pedders XAs and bushings, custom rear lower control arms, full length frame connectors, bottom painted hot rod black with IOM suspension. 125 wet plate nitrous, 175 direct port with dedicated fuel system, FAST LSX intake, Meziere electric water pump. All lines converted to Hard SS or black braided. Vararam, remote oil filter, billet valve and coil covers, aluminum and carbon fiber engine panels custom stereo with eclipse amps and 12'' sub in custom box, billet alum/carbon fiber/plexiglass trunk floor. GTS fenders, Evolution nose and hood with custom scoop
    Started but not done: custom paint, custom interior with 4 GTS style seats.
    Not the fastest but close enough for Rock and Roll.
  4. #24
    Not feasible.
    Do it with AN tube adapters.
    The steel PCV tube coming out the front of the valley plate (LS3,LS2,L76 hardware AFM deleted) is 3/8" OD with an expanded barb right on the tip.
    The steel tube (for fresh air supply) going into the passenger side valve cover is the same.
    Trim the barb off with a tube cutter then slip an AN tube adapter on and tighten it up.
    Part No in red is 316 stainless steel from Swagelok.
    3/8 OD tube to -6 AN
    Russell and Earls etc sell similar in pretty colours.
    On the side of the intake manifold the plastic tube coming out is 10mm OD.
    Again you can do it with tube adapters but due to the metric tube you'll need two fittings to get back to AN. The two fittings go into each other so it still looks quite neat when assembled.
    Part Nos are 316 stainless steel from Swagelok.
  5. #25
    Capitol City G8 G8V8's Avatar
    Jacksonville, FL
    UPR is a nice unit. fits great and is already catching oil.
    HSV E3 Bumper and Fenders
    VMS DoD-Delete with heads
    TVS1900
    RCR TB
    Kooks 1 7/8 Mids+SOLO Mach
    ZL1 Brakes
    Roto-Fab
  6. #26
    Here's a a couple of pics of mine, installed yesterday. Pretty simple...
    Daniel
    My Beaters:
    2011 Ecoboost F150
    2011 Star Stryker
  7. #27
    VIP Member Rawyzf's Avatar
    Blaine, MN
    Looks great!
    Mine will be here on Mon. Do I need anything, or does it come with everything needed?
    [COLOR="#000000"]
    [B][COLOR="#000000"]
  8. #28
    VIP Member rmcrom's Avatar
    Sep 2009
    Aledo, TX
    Quote Originally Posted by Rawyzf View Post
    Looks great!
    Comes with everything.
    2009 Pontiac G8 GT :: MGM :: Premium/Sport :: Onyx/Red Leather
  9. #29
    Just need a flat-head screwdriver, somethin to cut the hose with, and a ratchet w/ a
    10mm deep socket. All this and you're good to go.
    Daniel
    My Beaters:
    2011 Ecoboost F150
    2011 Star Stryker
  10. #30
    Beyond Help gr8lover's Avatar
    SE Michigan
    Sorry for the newbie question, but why do we need one? Is this something important to get and what makes some need it and others dont? or should all of us get the oil catch can? benefits? negatives on not getting one?
    Thanks for info
