Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 47
Thread: Apple TV install DIY
  1. #31
    Junior Member aabry's Avatar
    Jun 2011
    Wouldn't a HDMI to RCA cable work also? This would eliminate a converter I would think...maybe I'm missing something.
    2009.1 Pontiac G8GT PBM
    FE3 w/ H&R Springs
    Spectre Intake w/ Custom HSRK
    X-pipe & GXP Axle-backs
    Polk Audio DXi650 Coaxial in all doors
    Kicker CVT 8s
    GT Mat 50mm Sound Deadener
    Paddle Shifters
    Costar Bluestar
    Maverick Man HIDs 4300K w/ Amperite Delay Timer
    Custom interior LED lighting
    GXP Rear Diffuser & Front Bumper Swap
    GXP Wheel, Aluminum Pedals and Premium shift knob
  2. #32
    Jun 2012
    Quote Originally Posted by aabry View Post
    Gotta have the converter to go from digital to analog, a cord can't do that.
    Sent from my XT1080 using Tapatalk
  3. #33
    Apr 2013
    Are you guys drilling holes in the side of your glove box for the cables? Also how are you getting the wire in the center console? I can't find anything on removing the back part of the console.
    Attached Images Attached Images
  4. #34
    Apr 2013
    Never mind, I found a DIY on the center console.
  5. #35
    Nov 2014
    I assume you will have to program your headset to VIM to use while driving, correct? If not, let me konw.
  6. #36
    Nov 2014
    Do you know if this works with the Costar Bluestar bluetooth?
  7. #37
    Dec 2014
    Maryland
    This may sound dumb but from the right up i was interested in knowing how you set up the router and are connecting to the wifi what internet do you use? Phone hotspot? or does it not have internet? If no internet how does your phone connect to the network? Not a network genius so im curious
  8. #38
    Oct 2014
    Hey guys,
    Completed my apple tv install a few weeks ago and had a quick question...
    I found a power inverter that has two usb slots which ended up being perfect....I plugged the inverter into the front cig lighter and placed in the glovebox.
    I put the apple tv in the little cubby hole under the radio head unit (very snug fit) which allowed me to use the remote.
    The hdmi to rca converters usb is plugged directly to the inverter along with the apple tv power cord.
    No usb brick, no extension cords, pretty clean install.
    The problem im having is i only receive video signal, unless i unplug the converter usb and plug it back in. Then i get both audio and video....
    Is anyone else having an issue with their hdmi converter?
  9. #39
    Feb 2015
    I'm from Australia and am looking to try and do this, thank you for the write up.
  10. #40
    Addicted Member terryscott621's Avatar
    Nov 2009
    Bringing this thread back from the dead!
    I'm looking into doing this mod on my car since I'm not crazy about any of the aftermarket radio options out there. I'd like to be able to fit everything behind the center dash to keep everything hidden and I think there's room for a small power inverter, apple tv, and router behind there. I had a question about the router though. I found the router linked below and was hoping that someone smarter than me about this kind of stuff could tell me if this would work for this setup. Thanks for the help.
    Amazon link:
    https://www.amazon.com/Edimax-BR-625...=edimax+router
    Link to product webpage:
    http://www.edimax.com/edimax/merchan...n150/br-6258n/
    Terry Scott
    2009 G8 GXP - Sport Red Metallic (#821 of 1829 / #33 of 74 as Optioned)
